2 switch light problem
Old 12-26-99, 02:39 PM
Guest
Angry
Help!
I have a 2-switch light. I replaced the 1st switch and tho't I'd connected the wires correctly, but now the 2nd switch (which I haven't touched) doesn't work. I changed the hot wires around, but the 2nd switch still doesn't work.
Ideas?
Thanks,
Frank
Old 12-26-99, 08:22 PM
Guest
Post
Hi Frank.
Were they (switches)working before?
Wuold the light come on?
Did you install a sw. with 3 screws?
Did you checked the bulb?
Regards Zoltan
Old 12-26-99, 08:26 PM
Guest
Post
Yes -- both switches were working before, the light works (overhead fixture), 3 screws on the new switch.
Thanks!
Frank
Old 12-26-99, 08:45 PM
Guest
Post
OK.
I assume that you did not alter connetion on second Sw.
So.
If the feed is in the new sw. box, you have 5 wires there.
A 2 wire & a 3 wire cable.(most usual)
2 white wires are connected together.
Black wire from 2 wire cable is connected to colored screw.
Black & red from 3 wire cable is connected to the white screws.
If in that box are only 3 wires (normally)
Black wire is connected to colored screw.
White & red is connected to white screws.
I am waiting for response.
Old 01-23-00, 09:45 AM
Guest
Post
hx98:
Thanks for your help -- solved the problem (only problem was finding time to do it in the post-holiday rush!)
fthomas
