determining Amps incoming to house
Old 06-07-02, 08:07 AM
Vaard
In middle of buying a new house (hopefully will be in by Aug 1) and have a couple questions about the electrical:
it was listed as a 100amp house....is there any way to upgrade to 200amp?
how do i figuire how much 100amps can handle?
how and when should i do inspections to make sure the it's all running fine?
thanks in advance for your help
Old 06-07-02, 08:22 AM
HandyRon's Avatar
To determine the size of your service, look at the size of the main switch or circuit breaker. Then remove the panel cover from that main, and see the size wire the feeds it. Generally, a 100A service should have #4 copper or #2 aluminum connected to the line side (input side).
Again generally, any service can be upgraded to 200A if needed. Some are harder than others, but they all can be done. Inspect the electric before signing contracts or after contracts (make the contract contingent on your inspection).
Old 06-07-02, 10:01 AM
Vaard
thanks alot
