Touch lamp failure
Greetings!My touch lamp works when you plug it in.But touch switch does not.
Any suggestions?Thank You ahead of time.
You module has failed. I would replace it with a normal mechanical switch, as touch
lamps are notorious for creating radio interference. If you insist on having a touch lamp, ypu can probably get modules from a
better home center, or a lighting specialty store.
