install toggel switch
Old 06-07-02, 06:53 PM
biscay
how to install toggel switch
Old 06-07-02, 07:52 PM
Received 1 Vote on 1 Post
Wiring a toggle switch is straightforward. Simply attached the unswitched hot wire to one screw and the switched hot wire to the other screw.
I suspect, however, that you are after more information than this. If you describe your project more fully, we can provide more useful information. Or you can pick up a book on home wiring at your local public library or home improvement center and it will tell you everything you need to do most home wiring projects.
Good luck.
