Converting Stove From Gas to Electric
Old 06-10-02, 08:21 PM
Question Converting Stove From Gas to Electric
I am trying to sell my gas range because I prefer electric. When we pulled it out from the wall to determine if there was a 220 outlet, we dicovered a thick cord which led into a metal box. Inside the box were two cords each capped off. My husband knows very little about electrical work so he isn't 100% sure that the cord was for an electric hookup prior to purchasing gas stove by previous owners. Is it more than likely this is what this is?
Old 06-10-02, 08:28 PM
Received 1 Vote on 1 Post
Yes, it is very likely that that is what this is. I think you just might be very lucky. Go to your breaker panel and see if there is a double-pole breaker (2 inches wide) that is labeled for a range. Come back and tell us what number is on the handle of that breaker.
Old 06-10-02, 08:39 PM
Number on Handle
The number on the handle is 50.
Old 06-11-02, 06:58 AM
You are indeed lucky. Sounds like you can just have a qualified person hook it up, after double checking to make sure the circuit's capabilities match the range's requirements.
