Moving a light switch
Old 02-29-00, 07:58 PM
Guest
Post
I need to move an existing light switch 4 feet from where it is currently. There is no slack in the existing wire. I could use the existing switch box as a junction box, and splice in a wire to the new switch box, but I thought code prohibited burying a junction box in a wall. The only wire in the existing switch box is the one going to the light.
Old 02-29-00, 09:25 PM
Guest
Post
hello bill,
yes the code prohibets a junction box from being baried they MUST be axsessabel. u have only 2 options here eather pull new wire 2 the light and new switch box or leave the current switch box exposed and blank plate it and use it as a junction box.
Old 03-02-00, 09:10 PM
Guest
Post
Thanks Sprky. I guess I'll run a new wire to the new switch location. If I disconnect the old switch from the power source, no live wires in the box, can I then abandon that box and cable, and bury that in the wall.
quote:<HR>Originally posted by sprky:
hello bill,
<HR>
Old 03-03-00, 05:40 PM
Guest
Post
hello bill,
thats not the most advisabel thang 2 do. u realy need to remove as much of the cabel as possabel.
Old 03-04-00, 02:03 PM
Guest
Post
i agree with sprky u need to remove the old wire just in case you ever sell your house and someone finds it and trys to reconnect it that would not be good
