Lights Dimming!
I just purchased a microwave and it is now plugged into a receptacle that can handle 125V and 15A. My problem is when I turn on the microwave the lights dim. Would a change of the current receptacle with one of 20A do the trick?
Please help
Please help
Outlet circuits should have 20 amp breakers and 12/2 wiring. Lighting circuits should be separate from outlet circuits, and 15 amp breakers and 14/2 wiring are o.k. on them. It is recommended that microwaves (and dishwashers,etc.) be on separate 20 amp breaker/12/2 circuits (and may be code. I'm not an electrician). Good Luck!
