lamp rewiring
Old 04-01-00, 02:21 PM
Guest
Post
I have a lamp with three bulbs. My wife has begun to rewire it. She has already remove all the old wiring. How do I safely rewire it properly? The bulbs are the pull switch type. Thanks
Old 04-01-00, 07:57 PM
Guest
Cool
The hot side of the lamp wire is smooth. The neutral side will have ridges or be imprinted. Connect smooth (hot) side to all brass screws, ridged/imprinted side to all silver screws. Neutral side of plug is wider blade. Good Luck!
Old 04-02-00, 07:08 PM
Guest
Post
hello ckline,
looks like old guy filled u in correctly. i might add that the hot goes to the button (small button in bottom of socket)of the light sockets and nutural goes to the shell (the threds that u screw a light bulb into. and the switch breaks the hot wire not the nutural.
