kitchen light works 99% of time
Old 04-06-00, 06:56 PM
Guest
Post
About once a month I'll flip on the switch
for the overhead kitchen light and it does not come on. I have replaced the light fixture and the switch. What should I do next.
Thanks
Mike
Old 04-06-00, 10:18 PM
Guest
Post
Could be most anything, based on what you have told us so far. First off, what type of overhead fixture do you have? Fluorescent or incandescent? Have you checked all of the connections in the circuit to make sure they are all tight? Is there a junction box between the light fixture and the switch? I would suggest that you repost with a few more specifics so somebody can provide you with more suggestions than questions
Old 04-07-00, 04:08 AM
Guest
Post
If you flip the switch again does it come on ?
Jack the Contractor
Old 04-08-00, 02:36 PM
Guest
Post
hello mick,
sounds like u have a loose connection some where in the circuit, since u replaiced the switch and fixture.
