light bulbs burning out too fast
The light bulbs in my bathroom are burning out too fast. We have replaced the fixture and they are still going out. Some are not burned out. They come back on after awhile then go back off.
What causes this and how do we fix it?
Thanks.
Thanks.
hello nseabolt,
sounds like u have a loose connection some where in circuit, start at the light and check all connections, if u find none then go to switch and check if none keep moveing back words on the circuit checking every box. it could also be in the panel if u need to check connections there be sure you turn off the MAIN breaker the lugs of main breaker will still be hot so dont touch them.
