electrical lighting outside
I have a new house with can lighting outsidein the front of house, I want to extend or add can lighting to back of house
hello karikay,
easest way to do this is to cut yourself a hole bog enough for the can ring to be in and get in attic connect 12/2 with ground if on 20 amp circuit 14/2 with ground if 15 amp circuit to existing can light color to color, and run to new can and wire color to color then install the can from attic into hole u cut.
