wiring
Old 06-24-02, 07:55 AM
Nazer
wiring
I have a 50 amp GFCI circuit breaker in my panel that I want to connect a 110 waterproof outdoor outlet box to. I know that the white wire goes into the breaker designated with the white dot, and that the pigtail wire goes into the bus bar. There are three slots on the breaker(for 220?) Does the black wire go into the slot above the wite wire or the slot below the white wire? Or does it matter? And the green is a ground, does it also connect to the bus bar?
Old 06-24-02, 09:55 AM
Received 1 Vote on 1 Post
Code does not allow the project that you are attempting. Install a new 15 or 20 amp circuit for your new receptacle.
