Electrical
Old 06-28-02, 09:24 AM
phoobear2
Electrical
How do you convert an A/C unit from 220 to a 110 line
Old 06-28-02, 09:30 AM
Received 1 Vote on 1 Post
You most likely cannot (except with a large and expensive transformer).
Old 06-28-02, 10:35 AM
Why would you want to make that conversion?
Old 06-28-02, 11:15 AM
phoobear2
I was told that you can convert from a 220 down to a 110 that is why I was inquireing
Old 06-28-02, 12:42 PM
T
220V to 110V is possible. It's not possible to go from 110 to 220V, at least not without a step-up transformer. If your appliance needs 220V then you need to bring 220V to that location (2 hot wires and a neutral). They also have to be on oposite phases (each side of the double breaker needs to be on different bus bars). This way you'll have 220V between the two black wires, and 110V between any black and white wire. You probably should have a ground wire also.
Old 06-28-02, 09:12 PM
Again,,, why would you want to do this,,, just curious?
Old 06-28-02, 09:29 PM
phoobear2 has a 220-volt air conditioner and a 110-volt receptacle. This is all being discussed in another thread also started by phoobear2.
