GFI breaker tripping
Old 05-11-00, 09:10 AM
Guest
Question
I have a GFI circuit breaker that is tripping for no apparent reason. It happened occasionally before but is happening regularly now. It supplies the garage and outside outlets. The breaker resets fine but seems to trip without anything on the line being used.
Any thoughts on whether it is likely a bad breaker or if I should have an electrician look for something else?
Old 05-11-00, 06:53 PM
Guest
Post
hello jlaidley,
sounds like u may have a bad gfci, unless u have a tester then replaice the outlet. if it keeps hapening after u replaice then ther is probily a problem in the wireing.
