breaker box
Old 05-30-00, 05:14 AM
Question
i'd like to see a breaker wiring installation/ layout
Old 05-30-00, 06:26 PM
Post
hello mario,
if u r asking for a wireing diagram on breakers this will all depend on wheather they r singel pole, doubel pole, gfci singel pole, gfci doubel pole.
i know of no wireing diagrams buti can tell u how they r wired. singel poles the black wire goes to breaker white goes to nutural bar bare goes to ground bar. on doubel pole breakers it all depends on wheather the load is a true 240v or not, a true 240v needs no nutural(ac, heating and the souch). true 240v is normaly wired useing a 2 wire with ground romex, and the white and black go to breaker and bare goes to ground bar. a non true 240v is normaly wired useing a 3 wire with ground romex with the black and red going to breaker white to nutural bar and bare to ground bar. a singel pole gfci is wired with the black to the breaker, white to the nutural lug on breaker, white on breaker to nutural bar, and bare to ground bar. doubel pole gfci breakers r wired with the black and red to breaker white to the nutural on breaker, white on breaker to nutural bar, and bare to ground bar.
your lines from the meter go to the MAIN breaker lugs with nutural from meter going to nutural bar, and if this is the main panel the ground bar bonds to the nutural bar(a piece of wire the same sized used to ground panel to ground rod ran between the ground bar and nutural bar).
hope this helps u out.
