can co\alr gorunding switches be used with copper wiring
Old 07-07-02, 09:35 AM
C
Received 1 Vote on 1 Post
just wondering if I can use co/alr grounding switch with copper wiring
Old 07-07-02, 10:35 AM
DaveB.inVa
Sure can! The co part of the rating takes care of that.
Old 07-07-02, 11:04 AM
C
co means?
cu I know is copper..
Old 07-07-02, 02:40 PM
Yes. CO/ALR replaces the older AL-CU and CU-AL designations. The "R" stands for "revised". Not sure why they decided to change the "U" to an "O" at the same time. Maybe they thought that not everybody had sufficiently studied their periodic table in high school.
Old 07-07-02, 06:01 PM
Wirenut33
Just wondering, but why would you want to use a CO/AL rated device on copper wire?? They run in the area of $3-5, while you can get a standard switch rated for use with copper only for around $0.36
Old 07-07-02, 06:46 PM
C
Good point. I just happened to have them in hand.
