ceiling fan light kit wiring?
Old 06-18-00, 10:12 PM
Question
I do not have a blue wire w/ which to connect a black wire to, and the black wire available does not work?...I have already tried a second light kit, after assuming the light kit switch was faulty...w/ no luck as well?. any suggestions?...Thank you, Gerry
Old 06-18-00, 10:45 PM
Post
When you remove the cover on the bottom of the fan, where the lite kit will attach, there should be a blue wire tucked in there labeled "light" for you to attach the black wire of the lite kit to. If there isn't one there, then the fan was not designed (nor wired) for the addition of a lite kit.
