Grounding 220
Old 07-09-02, 07:02 PM
Grounding 220
I have seen the error of my evil ways and am running a 4th wire to sub panels in my shop. Steel building. I did this many years ago and am correcting the error. Is a 12 wire adequate or do I need a 10? Can I hook the compressor grounds to the neutral buss in a sub? 220
Old 07-09-02, 07:06 PM
Received 1 Vote on 1 Post
Depends on the size of the breaker in the main panel that protects the hot wires. What is it?
No, you can't hook any grounding wires to the neutral bus in the subpanel.
Old 07-09-02, 08:18 PM
I have a 60 feeding the sub.
Old 07-09-02, 08:23 PM
MTgets
different breaker
I may be out on a limb here, but I think John wanted to know the size of the breaker for the compressor, not the breaker feeding the sub, if it is a 30amp you need 10 awg, 20 amp 12awg
Old 07-09-02, 08:47 PM
he asked for the breaker at the main. I need t get a code book,,, just havnt been to the supply store in a while. Been using HD for stuff and I looked there and no code books.
Old 07-09-02, 09:09 PM
Well, sberry27, you did answer the question I asked, but I can't seem to find the answer in the code. I think the answer is #8, but I'd like some support on that.
Old 07-09-02, 09:19 PM
Wgoodrich
If we are talking about the equipment grounding conductor ran with your 60 amp feeder you hots should be 6 awg copper with a minimum size equipment grounding conductor of 10 awg copper ran with that feeder to serve a four wire feeder to that detached garage per 250.122 of the NEC
If you are talking about the grounding electrode conductor from a ground rod to the panel in the detached garage John is right. You would need a minimum grounding electrode conductor size of 8 awg copper per 250.66 of the NEC.
Hope this helps
Wg
Old 07-09-02, 09:32 PM
Yes it helps,,, I bought a roll of 12 today for another thing,,, I guess its back for a roll of 10. Thats kind of what I thought,,, just wasnt sure. I will be out of your hair shortly as doon as I get 10 years of code violations fixed up.
