Sorely needed help w/unique light switches!!???
Old 07-09-02, 07:22 PM
nipsy
Hello, first time poster, any help would be appreciated. I know that light switches do exist wherein the toggle switch lights on when the light itself is turned off. I would like to know if anybody knows of any switches where the bulb can be changed to a different color. Just to avoid confusion, Im talking about the miniscule bulb, an LED perhaps, inside of the switch. Thanks for the help, I appreciate it!
Old 07-09-02, 08:38 PM
HandyRon's Avatar
If you want the led in the toggle on when the overhead light is off, then you are stuck with the led in the toggle (it's enclosed). If you want the led on when the overhead is on, you might be able to change the lens on a pilot light type switch.
The pilot light type is used for rooms where the switch is in the hallway, but the overhead light is within the room and you want to be able to see that the light is on without opening the door.
