Switches to outlet
Old 06-25-00, 06:54 AM
Guest
Question
The switch I have in my bedroom is supposed to controled an outlet, how can I do that?
I have 3 outlets in my room. I want the top outlet of thoses 3 to be controlled by the switch, Right now, it doesn't work.
Old 06-25-00, 09:56 AM
Guest
Post
Not sure what your existing wiring is, but what you need to end up with is a hot leg to the bottom brass screw of each outlet, a switched leg to the top brass screw of each, and a neutral to a silver screw. On the brass screw side of each outlet, break out the tab that connects the top and bottom screw. Hope this helps. <BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Mathieu Morin:
<HR></BLOCKQUOTE>
