GFI Outlet in Laundry Room?
Old 07-12-02, 01:59 PM
russellmania
Question GFI Outlet in Laundry Room?
We are selling our current home and after the buyer's inspection, we need to replace a 2-wire outlet in our laundry room with a GFI outlet. Question: Can we simply replace the 2 prong outlet with the GFI using only the 2 wires, and still comply with the code or do we still need to run a ground wire too? Our house was built in 1953.
Thanks!
Old 07-12-02, 02:43 PM
HandyRon's Avatar
You can directly replace it. A GFCI outlet works fine without a ground (green or bare) wire.
Just a note: most laundry rooms do not require a GFCI outlet.
Old 07-12-02, 03:33 PM
russellmania
Thanks HandyRon!
A GFI is not required even though there is a faucet and utility sink a couple feet away? The sink is on the opposite side of the room from the washer.
Thanks!
Old 07-12-02, 05:35 PM
pcboss's Avatar
Received 148 Votes on 131 Posts
Question
What is the basis for the GFI? The Code is is not retroactive, normally unless renovation is under way there is no need to bring things up to date.
