Fans in tiling
Old 07-12-02, 05:57 PM
winguardian
Question Fans in tiling
I am looking to install ceiling fans in all of my bedrooms. I have a problem though. My entire second floor has drop ceilings. How am I to support the fans I am going to put in. Some of the fans fall in the center of a tile, while others fall directly on the support beams. If anyone knows how to get fans hang on that stuff, please let me know. Thanks.
Old 07-21-02, 09:58 PM
Easiest way is to use threaded 3/8" threaded rod going from the fan rated box up to the house framing. They make a screw that has a wood lag thread on one end and a 3/8's machine screw thread on the other. If the Box falls in between the framing just add some 2x's to bridge it
Old 07-25-02, 10:26 AM
P
There is an electrical outlet box designed specificly for hung/droped ceilings.The box is fixed to a bar that clamps to the "T" rails and the box position is adjustable.I advise you to submit this question to the "Electrical" section of the Forum-Good Luck!!!
