When are inspecters req'd?
Old 07-14-02, 12:13 PM
bos4me
Question When are inspecters req'd?
When does it become necessary for an inspector to come look at home?
Replacing current receptical with GFCI?
For something like adding a GFCI to the kitchen?
Installing a new light or fan?
Or how about adding a new branch?
Old 07-14-02, 01:25 PM
Wgoodrich
The actual accurate dividing line as to how much you can do before an inspector must inspect your work depends on the ruling of the AHJ [inspector] in your jurisdiction. However most common break is as follows.
Minor repair [replace a receptacle or hang a light fixture to existing box is normally minor repair. Replacing a breaker or GFI protective device in normally a minor repair.
Any time you change the integrity of your wiring such as running a new wire of any kind calls for a permit and inspection.
To know you limits to be exact get a ruling from your AHJ He or she is the final call on the subject.
Hope this helps
Wg
Old 07-15-02, 02:48 AM
bos4me
Thanks for the info WG......
Old 07-15-02, 04:31 AM
thiggy's Avatar
I have asked that question of my inspector in the past, and was told that in our community a homeowner cannot by law do more than change a bulb or plug and unplug appliances without a licensed electrician. Hence, a permit would be required as well as an inspection. About 25 years ago, I built an addition on my house. I took a test on the electrical code and was allowed to pull a permit and do the work myself. More recently, (4 years ago) I was getting a permit for enclosing a porch and was told by the same inspector that the city no longer issues homeowner electrical permits. That said, he did suggest if I knew an electrician who would get the permit for me, that it would be OK with him, since he knew that I knew what I was doing.
It just depends on the law where you live and the reasonableness of the individuals responsible for enforcement.
Old 07-15-02, 08:05 AM
Sparksone42
Repair or replacement does not require a permit. Any alteration or change requires a permit and inspection. Most agencies have done away with owner-builder permits in the electrical area.
In essence if you move a switch one inch, a permit is required!
