Fluorescent lights and cold
Old 07-15-02, 02:23 PM
K
Question Fluorescent lights and cold
I would like to put a fluorescent light above my workbench in the garage (unheated). Are all fluorescent lights sensitive to the cold? I am in Wisconsin and there may be times when I would like to have some extra light in the middle of winter. I thought a fluorescent fixture would be the best way to go but I don't know what temperature range the lights will be able to operate.
Any insight or suggestions are appreciated.
thanks
Old 07-15-02, 03:44 PM
Wgoodrich
A rapid start flourescent fixture will start giving you lighting trouble about 45 degrees.
If you want to install a flourescent light fixture in cold settings try a high output flouresent fixture. It can take sub zero temperatures.
Hope this helps
Wg
