Install Garbage Disposal
Old 07-16-02, 08:55 AM
mloman
Hi. I want to install a garbage disposal (fresh install, not a replacement) and want some advice about the wiring. I have a 20 amp circuit (#12 wiring) running to the area under my sink - there are no other appliances on this line.
I need to run the wire to a switch (under my sink & mounted on the inside of the cabinet). Is it Ok to use a metal switch box under the sink? or should I use a watertight plastic switch box (the kind that people use outdoors)? Also, what should I use to cover the cord going from the switch to the disposal, and the cord running from the hole in the floor to the switch?
I understand basic electricity and wiring, but I'm unfamiliar with electrical codes. I want to make sure I do this right!
One more thing, what is the greatest horespower disposal I can install on this line?
Old 07-16-02, 10:14 AM
Gary Tait
You should couver both with flex conduit.
Old 07-16-02, 12:30 PM
mloman
Can I use a metal switch box, or should I use plastic?
Old 07-16-02, 01:16 PM
Mike Swearingen's Avatar
Received 1 Upvote on 1 Post
Cool
Either box is fine, and you don't even need a GFCI outlet under a sink.
If you have a dedicated 20 amp circuit (a dedicated 15 amp circuit is usually required for a dishwasher), you should be able to run just about any residential disposal on it (as well as a dishwasher).
Check the electrical specs on the disposal or the info sheet that comes with it. Should be no problem with a 20 amp circuit.
Good luck!
Mike
Old 07-17-02, 07:26 AM
Hatteras
A 20 amp, 120 volt circuit is good for 2400 watts (amps times volts = watts.) 746 watts = 1 HP so your 20 amp circuit is more than adequate to handle a agrbage disposer.
Hatteras
Old 07-19-02, 08:14 AM
mloman
Thanks guys, I finished the installation and it works wonderfully.
