flickering lights
Old 07-09-00, 02:05 PM
G
Guest
Talking
Could a bad dimmer cause lights to flicker?
Old 07-09-00, 03:11 PM
G
Guest
Post
More than likely, the problem is a loose wire inside a junction box and vibration is causing the wire to separate and the light flickers. Check your connections at the dimmer switch and at the light first.
