basement wiring
Old 07-16-00, 12:02 PM
Guest
Post
I want to connect all the lights in my basement to a light switch. There is power going to 4 different light fixtures, but currently they are not connected to a switch. Any suggestions?
Old 07-16-00, 01:48 PM
Guest
Post
You need two conditions to be true before
you can connect them all up to one switch;
1: They all must be on the same circuit.
2: The must be interconnected with wiring
dedicated to them.
Once those conditions are met, you simply need to install a switch and box, run wire
between the swith and a point where you
can control power to all the lights.
