Adding light to exsiting switch??????????????
Old 07-18-00, 07:33 PM
Question
I am adding a light fixture in a bathroom is it possible to wire right into the exsiting light switch??????????? If so how????
HELP!!
Old 07-19-00, 01:23 PM
Post
If there is a neutral there, simply connect
the new fixture's neutral to it, and the new fixture's hot to the switched side of the switch (using a pigtail, never double up
under one screw).
If the switch is an end of run, you must wire
into where there is a neutral and a switchleg, such as the other fixture, or
you must run a 14/3 (or 12/3 if original is #12) between the switch and where the original 2 wire cable went.
