Which table saw??
Old 12-03-02, 09:18 AM
CLIMBNUTT
Which table saw??
I'm in the market for a new table saw.I am not a proffessional woodworker or carpenter so the work I would be doing will be kept in the basement-light woodworking projects,etc.I am confused about belt drive vs. direct drive.Am I wasting my money buying a direct drive? I have my eyes on a delta for around $220.I realize the belt drives are more expensive but I don't want to spend much more than $250. Are direct drives worth buying?
Old 12-03-02, 01:00 PM
GregH's Avatar
Super Moderator
Received 35 Votes on 33 Posts
CLIMBNUTT:
You really don't get much for $250.00.
A table saw is the heart of a woodworking tool collection.
A budget is a budget, but might be one you may not be sorry blowing or waiting untill you can afford a better one.
I have seen some decent direct drive saws. The difference is in the mitre guide, fence and top.
Old 12-03-02, 06:02 PM
Specter
There's not much that can go wrong with a table saw that will cost much to fix except the motor. With a direct drive, it means a major cash out lay to replace it. With a belt driven saw, it's just the motor. While not all that cheap either, it's a lot less expensive that the direct drive. You may get lucky & find an inexpensive motor.
Also, once you get a table saw, you'll be surprised at all of the cutting you will use it for that you use to do with a circular saw.
Old 12-04-02, 04:31 AM
B
Received 3 Votes on 3 Posts
I have a belt drive Craftsman. The thing really like about it is that I was able to put an adjustable sheave pulley (not sure if thats the right terminology) on the motor so that I can adjust arbor speed for different attachments. Just have to be careful not to exceed recommended speeds for the various attachments.
BTW, my dad has a Craftsman table saw with a cable that drives the arbor. After about 3 or 4 years the cable broke and it cost well over $100 for a new one.
I also agree with GregH, $250 doesn't get much in a table saw. I've found that it's usually accuracy that suffers at the lower end of the price range; even if you don't do much woodworking, it will be a real frustration if you can't get the accuacy you want. Seems like every time I buy a cheap tool, I regret it. But then, sometimes a person has to live withing a budget, period.
Bruce
Old 12-04-02, 04:54 AM
fewalt's Avatar
CLIMBNUTT,
Years ago my first saw was a Delta benchtop. Smaller saws do have their limitations, but you sort of learn to live with them.
Now I have a contractors' saw and know there is quite a difference. Here's some good insight you should read prior to your purchase:
http://www.woodworking.com/ww101et-table.cfm
fred
Old 12-04-02, 05:01 AM
CLIMBNUTT
Thanks guys that's pretty much the consensus I've been hearing -i guess the difference between the belt drive and direct drive is like night and day.Thanks a million!!
Old 12-04-02, 06:01 AM
arthropod98
the first "major" tool i bought was a delta benchtop table saw, for about $130. it lasted for a nice long time, and worked . . . well . . . allright. but, i bought that about 2 years ago, and with the amount of wood-working i've been doing, i've been BLESSED with an upgrade to the ridgid TS3612 -- about $600, i think.
it's a tough call to make, but once you start with wood-working, you may be HOOKED, then you'll be doing an upgrade eventually too . . . just something to keep in mind.
oh, the delta was a 10" direct drive (louder), and the ridgid is a 10" belt drive (much quieter, with way more power and cutting area).
the old delta will be going to a friend, so it wasn't a complete waste, but i coulda saved $130 right from the beginning. of course, i really didn't realize how much i would ENJOY doing all this!
so, there's, basically . . . well, NO answer for ya!
