need to replace keyless chuck on my craftman
Old 12-03-02, 09:37 PM
bluedreamer
Unhappy need to replace keyless chuck on my craftman
Help I got this drill as a present and one of the prongs never came out the drill was used when I got it so no instructions are on hand I need help.
Old 12-04-02, 07:32 AM
thiggy's Avatar
Open the chuck as wide as possible and take a look inside. If there is a screw on the end of the shaft holding the chuck, unscrew it. Then grasp the chuck firmly and give the drill a squirt in reverse to unscrew the chuck from the shaft.
Old 12-04-02, 11:42 AM
GregH's Avatar
Super Moderator
Received 35 Votes on 33 Posts
bluedreamer:
If the drill was a recent gift, this would be a warranty issue.
The subject of chuck removal, if this is where the "prong" is you are referring to, has been discussed at length a few posts down.
Old 12-04-02, 11:57 AM
thiggy's Avatar
Blue said the drill was used when he received it, so it probably is not under any warranty.
Old 12-04-02, 12:37 PM
GregH's Avatar
Super Moderator
thiggy:
Maybe your right.
Grammer makes a big difference.
