Air Compressor
Old 12-17-02, 09:04 AM
W
Air Compressor
My Ingersoll-Rand Bench air compressor has stopped
working. It seems to run okay. It creates very little
preasure though.
Any ideas on what the problem might be?
Thanks
William
Old 12-17-02, 12:12 PM
thiggy's Avatar
If it is a diaphram type compressor, I would suspect a crack in the diaphram.
Old 12-17-02, 04:19 PM
scrapiron
Mabye a broken reed valve in the head. It works like a check valve and it can be replaced.
Old 12-18-02, 03:59 AM
GregH's Avatar
Super Moderator
Received 35 Votes on 33 Posts
Wilket:
What type is it and how old?
Did you check the air filter?
Old 12-18-02, 06:40 AM
W
Smile
The compressor is Ingersoll-Rand portatble/bench (piston type).
The problem is in fact a broken reed valve in the head.
Thanks for the diagnosis!
Where can i find this part?
Thanks again for the help!
William
Old 12-18-02, 09:02 AM
Joe_F
Just about anywhere actually. If you go to Sears.com and plug in the model #, they may have a breakdown there with the part #. In turn, you can shop around for that part #.
Alternatively, you can contact Ingersoll Rand and ask them. I believe the URL is www.irco.com. If not, go to www.google.com and type in "Ingersoll Rand Compressor parts". You'll find more sources than you need. LOL.
