1/4 sheet palm sanders
Old 12-20-02, 08:48 AM
Mekanic
Question 1/4 sheet palm sanders
I am in the market for a 1/4 sheet palm sander. Any recommendations?? I am considering the Makita or the Black and Decker models. Thanks
Old 12-20-02, 09:38 AM
josh1
i dont have either of those, i have a craftsman one i use alot for auto body prep. The thing I would look for- How easy is it to switch sheets of paper? ie what type of clips. THe crapsman has metal spring clips along 2 sides with a lever you lock back, however all the vibration sometimes makes the lever stick, then I need to pry it open. Id recommend you actually try how it changes. -Josh
Old 12-20-02, 09:57 AM
B
Received 2 Votes on 2 Posts
I have a Makita and it's an excellent sander.
Bruce
Old 12-20-02, 04:48 PM
sandy2000's Avatar
My-Kita is good!
I have been using my Makita for home & craft projects for 10-12 years and hopefully won't have to replace it. If has been very reliable.
Old 12-28-02, 10:00 PM
L
lnmrosen
I have the Porter Cable. It works fine. The price is very close to the cheaper models. I recommend that you get the velcro base which is an accessory.
