which blade to use
Old 12-30-02, 01:05 PM
dougroot
Question which blade to use
I am remodeling a bathroom and I need to make a straight cut
down a wall of tile.
The tile has a bed of mortar behind it about 1-1.5" thick
Can I use a circular saw w/a diamond dry cut blade to cut
through it?
If so what kind of blade will work for the job?????
Old 12-30-02, 09:07 PM
I would use a blade for masonary to make the through cut. If there is one specifically for tile available, use it to make a scoring cut in the tile itself. If this is the only time that you will likely use the blade, go with a tile blade and make the entire cut with it.
