gazebos
Old 01-24-03, 05:44 PM
gordypoo
gazebos
hi, i'm a newbee, question is, i'm building a octagon gazebo, 8'er. got the pie shaped floor done. i'm putting the rafters on a 5/12. i want to make a metal cap, i know i will have to cut 8 pcs of metal & flang them, then melt lead on reams, cant find a tool to put the flanges on, i figure the tins will be 12" long, any help would be appreciated. thanks, gordon
Old 01-24-03, 09:40 PM
GregH's Avatar
Super Moderator
gordypoo:
Is this what you had in mind?
http://www.houseoftools.com/product.htm?pid=14562
Old 01-26-03, 02:56 PM
gordypoo
gazebo
i looked at that web site, it didnt have what i needed, i tried tinsmithing & lots of info, but not what i need, i guess i'll just use rivet it, thanks, gordon
Old 01-26-03, 04:15 PM
GregH's Avatar
Super Moderator
gordon:
I must not understand what you are looking to do.
Old 01-27-03, 09:45 AM
gordypoo
GAZEBO
HI GREGH, I AM TRYING TO MAKE A GALV CAP FOR AN 8 SIDED GAZEBO. I WANT IT TO FIT FLUSH AS POSSIBLE TO THE ROOF, I ALREADY MADE A FORM & HAMMERED THE TIN TO FIT, IT WAS A MESS, I HAVE BEEN TO ALL THE WEB SITES, AND NONE ARE MADE. I AM A RETIRED CARPENTER & INTEND TO TRY TO BUILD THESE G'S & I THOUGHT A NICE TOUCH WOULD BE A METAL CAP. I SEE THAT YOU ARE A/C & HEAT PERSON, SO WHATEVER TOOL THAT IS USE TO PUT THE FOLD OVER CRIMP ON THE METAL DUCT WORK, THAT IS WHAT I AM LOOKING FOR, I AM GOING TO CUT 8 PIECES OF TIN ON THE 22 DEGREE ANGLE, EACH PIECE NEEDS TO BE CRIMPED ON EACH SIDE SO THAT THEY WILL SNAP/LOCK TOGETHER, THEN I CAN POUND THEM FLAT,
Old 01-28-03, 04:58 PM
GregH's Avatar
Super Moderator
gordypoo:
The tool that makes the fold to join two pieces of sheet metal together is a lock former.
It is a fairly big machine and the joints it makes would be quite unattractive.
If you take a pattern or drawing to a sheet metal fabricator they may have an idea for you, or could make several of them for a decent price.
If you can download a PDF file, there is a sheet metal tool catalogue that has every tool imaginable.
http://www.empire-machinery.com/intro.html
Old 01-29-03, 07:57 AM
brickeyee
Talk to the sheet metal shop. Copper would be better than galvanized, and they can probably make it from one piece with a single flat seam.
Old 01-29-03, 02:14 PM
gordypoo
GAZEBO
thanks for the input, will follow up on all. gordon
