Power Washer
Old 02-07-03, 01:41 PM
W
wtm113
Power Washer
I like to buy a power washer so I can wash my car. What size or PSI should I get? I dont want to peel the paint off my car either...
Old 02-07-03, 02:43 PM
T
Power washer
The guys in automotive have posted several responses to this question you posted in the Automotive Forum.
Old 02-11-03, 08:25 PM
GregH's Avatar
Super Moderator
Received 23 Votes on 22 Posts
wtm113:
Your choice of pressures would depend on whether you want an electric or gas powered washer.
An electric one will be limited to the pressure that can be sustained by a 120 volt circuit.
I would get the highest pressure that will work on a 15 amp plug if that's the way you want to go.
You will have more choice if you go with a gas unit.
1500 psi at 2 gal/min flow would do a good job for you.
The water flow rate is just as important, if not more so than pressure.
