power band saw
power band saw
I have a Black and Decker power band saw and the blade has come off the pulleys. I and another person today have spent over two hours trying to reinstall the blade on the pullies without any luck. I have the instruction manual and have followed it. I presume there must be a secret that I'm missing. Can someone tell me how to do this or what to look for as to why this won't seat on the pulleys. Thanks
lefty:
As lefty says you need to adjust the tracking.
To replace a blade you would release the tension on the upper wheel install the new blade and then retension the wheel.
Turn the wheels by hand to get a good idea if it will track reasonably straight and then if it looks good, turn on the power to the motor for only a brief moment to assure straight tracking.
If you didn't release the tension and just wound the blade on the wheels it is likely outa whack.
What model of B&D?
What model of B&D?
