Cut a padlock
Old 06-25-03, 11:10 AM
gotafly410
Cut a padlock
Just bought a pait of H.K. Porter 24 in. Bolt Cutter
http://doityourself.com/store/6906952.htm
Will I have a problem cutting a Bell padlock with them?
Old 06-25-03, 11:33 AM
GregH's Avatar
Super Moderator
Received 67 Upvotes on 61 Posts
gotafly410:
You don't really say what size padlock and if it's one of those "can't cut it with nothin' but a torch" kind of lock.
I have a 36" cutter. It will go through most 5/16" locks like butter, a 3/8" you have to apply a fair bit of force. I've never tried a 1/2" lock.
A half inch grade 5 bolt is easy and I've never tried a grade 8.
Yours being a 24" would cut slightly less than mine.
Old 06-25-03, 11:46 AM
gotafly410
It measured an inch around the bolt. Is that how you measure it?
Old 06-25-03, 12:08 PM
GregH's Avatar
Super Moderator
The measurement of a lock is by the diameter of the shackle or the round part that goes through the hasp or chain or cable you are securing.
That's assuming it's this kind of lock:
Describe in detail what you have.
Old 06-25-03, 12:31 PM
gotafly410
Thanks. It was 3/8. It cut it just fine.
