Jammed blade clamp on Tiger Saw
Old 07-10-03, 10:52 AM
tooltimer
Unhappy Jammed blade clamp on Tiger Saw
Recently bought a Porter Cable Model 735 Tiger Saw. Was cutting a branch off a large juniper root ball. Apparently the 9" blade hit the ground several times while I was sawing, & it pushed the Quik-Change blade clamp back into the saw housing. Is there a way to get the clamp back out, or will I need to take the saw to a dealer for repair? This is only the 2nd time I have used the saw.
Old 07-10-03, 11:49 AM
According to the owner's manual
http://media.ptg-online.com/20030407...- 04-09-03.pdf
you should be able to move the clamp forward so that it extends from the housing exposing the clamp. The manual says to plug the saw in and briefly pull the trigger to get the clamp to move forward. Then unplug it to work on it.
I hope this helps.
Old 07-11-03, 09:20 AM
tooltimer
Thanks!
You're right. A friend came over and immediately turned it on and made the clamp come out. I was afraid to turn it on because I thought I might break something.
I feel like such a ditz!
Old 07-11-03, 11:12 PM
There is nothing wrong with being cautious and protecting your investment in your tools as well as avoiding injury doing that which you don't understand.
