Saw Blade choice?
Old 08-03-03, 08:00 AM
Question Saw Blade choice?
Hi,
I have some 1/4"thk x 1 1/2" wide aluminum to cut with a jig saw.
How many t.p.i. blade should I use for this?Thanks
Old 08-03-03, 09:58 AM
GregH's Avatar
Super Moderator
cschroth1:
For a smooth cut 14 tpi would be my choice, faster cut would be had with 12 tpi.
Old 08-05-03, 02:47 PM
brickeyee
Rule of thumb is a minimum of 3 teeth in contact with material being cut. For softer items and rough cuts (wood typically) you can slip to 2 teeth. Stroke has a little to play in this since you would like the teeth to clear the material so the gullets can empty. To fine a blade will prevent this and the blade will clog up and cut very poorly. Bandsaws will clear the gullet, but can fill before passing through the material and clog also.
