Screw extractors
Old 08-14-03, 08:34 AM
D
Screw extractors
I'm replacing an old casement sash. The screws are stripped. I tried a screw extractor, but it didn't do anything. I left spun it in the drill.
What is the proper way to use this tool?
Thanks,
Sherm
Old 08-14-03, 09:28 AM
thiggy's Avatar
It depends on what type of extractor you have. If you have the traditional 'Easy Out' remover, you must drill the appropriate size hole in the body of the broken/stripped screw. then turn in the Easy Out with a thread tap handle. If the extractor that you have is the newer type which has been recently advertised heavily by Sears, I believe these are designed to be used in a screw gun run in reverse. I think they just tend to 'dig in' the head of the stripped screw and hopefully back it out.
Old 08-16-03, 08:53 AM
Back when I still worked for a living I used left-handed drill bits quite a bit. You know how a drill bit will grab every so often? With a LH bit that works for you and quite well at that. Not sure if that will be the best solution for you but in the right application they are great.
Jester
