Tool for Tyco Toy - yes, a toy
Old 09-03-03, 09:48 PM
4Deb4
My son received this Tyco RC remote controlled motorcycle dohickey for his birthday which requires a separate battery pack. This battery pack inserts through the bottom with no cover plate - instead, it has a little knobby thing on two sides - about the size of a small thumb screw. These little round things have to be turned to hold the battery in place (cam type thingies). The diameter of this knob is approximately a half inch and has a rectangular protrusion in the center - 1/2" length X 1/8" width and is seated in a recessed area. I have the most difficult time trying to turn the lock in place. The problem is I have semi long nails (not falsies) so I'm trying to turn this thing with my fingernails as opposed to my fingers. I'm looking for some kind of a tool that is small enough to get in the recessed area, plus strong enough to turn the knob. I realize I could cut my nails but I use them in everyday life - scratching backs, cleaning dried up gunk from the table, scratching my feline's neck - besides, they look very feminine. I would sure appreciate any ideas of tools that can be used (I've already tried needle nose pliers).
Old 09-03-03, 10:27 PM
C
If you could post a picture of the cover and its knob, we might be able to figure something out for you. If you don't have a place to post it just send it to me. [email protected]
Hope this helps.
Old 09-04-03, 03:51 AM
GregH's Avatar
Super Moderator
Received 35 Votes on 33 Posts
4Deb4:
This sounds an awful lot like a job for a slotted screwdriver.
<img src="http://images.animfactory.com/designs/photo_clips/workshop/tools_screwdriver_flat_head_wood_handle_md_sdw.gif">
Old 09-04-03, 07:34 AM
4Deb4
Troublesome Toy
I don't have the capabilities of posting a picture. The slotted screwdriver would be absolutely perfect if it had a female end as opposed to a male end.
Old 09-04-03, 09:02 AM
mattison's Avatar
What about some needle nose pliers?
Old 09-04-03, 10:50 AM
brickeyee
Flat Nose pliers.
Old 09-04-03, 02:50 PM
4Deb4
I have tried flat and needle nose pliers - I wouldn't be surprised if you missed it - it was the last line of my "dissertation." Thanks!
Old 09-04-03, 05:19 PM
brickeyee
Needle nose are not flat nose. You only said you tried needle nose. Flat nose are around the same length as needles, but are around 3/8 wide.
Old 09-09-03, 05:24 PM
sandy2000's Avatar
Check yellow pages
check your yellow pages for a "good hobby store" that handles RC equipment. They should be able to help.
