Air compressor tripping breaker...
Old 10-09-03, 07:07 AM
confutatis
Greetings to the forum,
I've become the proud father of a DeVilbiss 5hp-30 gallon air compressor. The compressor is rated at 15 amps. Unfortunately, the load it's creating on startup and its "cut in" are tripping the 20 amp breaker in the main panel inside my house.
Short of having to supply more power to the garage (Something Ijust won't be able to do in the near future), is there anything else I can do to lessen the load or the "sensitivity" of the circuit breaker (different circuit breaker, maybe?)?
Thanks in advance to the forum for any advice offered.
David
Old 10-09-03, 12:04 PM
Ed Imeduc's Avatar
Received 1 Upvote on 1 Post
aircompressor
Did I miss something here. 5hp just 15 amps?????
My book said 5 hp 56.0 amp full load 110 volts
5 hp 28.0 amp full load 240 volts
just my .02 cents ED
Old 10-09-03, 01:10 PM
brickeyee
Those are imaginary horsepower.
It actually is the locked rotor current at full line voltage converted into horsepower. Of course it is impossible to use the motor under these conditions. Peak developed my… you know what goes here
