Concrete drilling
Concrete drilling
Hi all,
I need to drill two four inch holes through my foundation wall. I'd like to avoid jack hammering and use some kind of drill or coring tool that will leave a respectable looking hole, so whats out there?
Thanks for the help
John Landy
Thanks for the help
John Landy
John:
A core drill with a 4" bit would give the best looking hole.
To use one you would drill one or two 1/2" holes, depending on the unit. With these you would securly bolt the baseplate for the core drill and then assemble the drill. A water line connects to the drill to flush the waste concrete away and cool the bit.
Image credit: powertoolstore.com
An easier way would be to rent a rotary hammer drill with a 3/4" carbide concrete bit and a small chisel.
You could drill a series of small holes and then clean up the edges with the chisel. This is what I normally do.
If you need picture perfect holes you could find a piece of steel pipe and grout it into the hole.
image credit: powertoolstore.com
Note that some rental places won't rent a core drill to a novice as the bits cost hundreds of dollars and are easily damaged.
foundation hole
Be careful. If you use a hammerdrill thats powerful enough to drill thru a foundation, It will have tremendous torque.If bit jams in hole you will not be able to hold on to it. Can break arms and jaws. Hilti makes one with automatic torque control(ATC). Drill stops if bit jams. I own the TE76. It does what it says it will do. very safe.Ask for a drill with(ATC) where you rent.
