how to remove stripped screws
I was screwing in a bronze 1" 1/2 screw into
a solid piece of wood. Before i could screw it all the way in it stripped, i then did the same with the next screw.
The screws are in real good, but they must be solid with the wood, and i need the peice i was screwing in.
Any suggestions would be very helpful, thanx.
teqeeler:
There are a number of ways to do it.
A pair of small wire cutters can sometimes get a good grip on the head
If you have a Dremmel tool you can use a grinding disk to cut a slot in the screw or a pointed attachment to remove enough wood around the screw to get a grip with a small Vice Grip.
How about drilling the head, patch the resulting hole with matching filler and then relocating the screw.
Maybe if you took a driver one size bigger you could hammer the screwdriver into the worn head to get a better grip.
Sears is flogging a bit for screw removal but don't know if it works.
Image credit: Sears.com
An impact driver will also work in some cases:
Image credit: DIY.com
Square drive
Are your stripped screws phillips head? If slotted, use the Dremel and convert them to phillips. I've read that a square drive screwdriver bit will fit a phillips and give it the needed contact for removal. Let us know what you end of doing. I'm no welder but could you do a quick (so you don't burn the wood) spot weld of a nut to the screw head and then use a wrench?
Hi there,
I use a small set of vice grips to remove stripped screws. Usually you can get a grip on the head without any filing and it works like a charm. You can either put them on flat and turn continuosly or face first and turn like a screw driver. Just one thing be careful of the wood since they have a tendancy come of the head with some force if they slip.
Good Luck
F.O.G.
Good Luck
F.O.G.
