Orbital sander as a buffer?
Old 12-06-03, 01:09 PM
sandy2000's Avatar
My wife uses a product, similar to car paste wax, on the bathroom countertop. Does anyone make a 5" hook and loop buffing pad that SHE could use to buff the wax off? I've never seen one at the big box places.
Old 12-07-03, 07:13 AM
GregH's Avatar
Super Moderator
Received 67 Upvotes on 61 Posts
sandy2000:
I've used a buffing pad that is for those cheap polishing kits for electric drills.
The pads tie on with a drawstring.
Make sure you tuck the loose piece of string under the pad.
I'd hate to see a finger wrapped aroung the shaft of the ROS!
Also, be carefull not to put too much pressure on the tool as polishing may put a bigger load on the motor than sanding.
Old 12-07-03, 12:01 PM
bubinga1
I got one at HD a few years ago made by Bosch.
Old 12-07-03, 12:04 PM
C
I have been checking out the ROS sanders for a week or so now trying to figure out which brand will be next.
I think it is Bosch or Makita that has a lambs wool polishing disk for ROS sanders. I also believe that it is only meant for low speeds on a variable speed sander. I wouldn't want to be very close to a "buffing wheel" going 12 to 14000 rps!
Changeling
