brad vs. finish
brad vs. finish
I'm told you use a brad nailer for furniture and small trim and you use a finish nailer for large trim, like baseboards.
I'm hoping to avoid buying two nailers, so can I push the limits of a brad nailer and use it on baseboards and other large trim? What if I used liquid nails and then a brad nailer for the larger trim?
A finish nailer will shoot as small as 1.25 inch nails. A brad nailer seldom goes much above that. Baseboards go down with #6 and shoe molding goes down with #8. Not much of an environment for a brad nailer. A finish nailer is much more versatile all around than a brad nailer, in my experience.
Hope this helps.
Hope this helps.
My inexpensive 18 guage brad nailer will shoot up to 2".
They hold baseboards very well and if I buy colored head brads they don't need filling.
Well, almost never
Really thin stock sometimes splits if you get too close to the end. I've been known to reduce the air pressure and let the brad drive a little proud, then finish it with a nail set
Palm nailer
Sounds like a brad nailer will work. Do folks think a palm nailer is a good option for a DIY'er like me. It seems it wil drive any nail, but lacks for speed. Since I'm slow anyways, why not
I've never used a palm nailer, but have seen them used. Looks like they're great for working in tight spaces. They also look like a sure-fire way to get carpal tunnel syndrome.
You will find that a good finish nailer has a soft/larger shoe than a brad nailer. The brad nailer may leave unwanted marks in your molding because of it's sharper shoe...especially if you apply pressure with the brad nailer to force a molding down.
jimmymc
jimmymc
