tamper proof screws
Old 12-29-03, 01:40 PM
tamper proof screws
I hate to admit it, but 2 tamper proof screws are winning the fight to remove them. My dog chewed the new iron cord and I need to replace it. Should be easy except I cannot get past the screws. The screws are smooth on top except for two indentations on opposite ends. Think of it as a flat blade screw with the middle section filled in. The screws are set deep into a the pastic case preventing access for the vice grips. Any ideas?
Old 12-29-03, 04:53 PM
re-mix
apiersma,
This place may be able to help.
http://www.tamperproof.com/products.html
R
Old 12-29-03, 06:21 PM
Manhattan Supply ( I think msc.com , but I'm not 100% sure ) also contains screw drivers and bits with the two dot pattern you mentioned. Make sure to order the proper size. Just like other screw drivers they come in sizes, a flat blade or Philips will accept the wrong size but the two dot screws require the correct size.
Old 12-29-03, 08:57 PM
Sharp Advice's Avatar
Admin Emeritus
Hi: apiersma
Might I suggest the diy store.
Check the diy members store pages.
Great products, member prices and excellent service.
Do It Yourself Store.
http://doityourself.com/store/index.htm
Additional Pages:
http://doityourself.com/store/handtools.htm
http://doityourself.com/store/powert...ccessories.htm
Or click the "Main Site Page" link above.
Banner ad also has special deals this time of year...
Regards & Good Luck
Web Host & Forums Monitor
Old 12-30-03, 07:34 AM
Great info .. thanks
I found a link to:Lara tools
It, like the other sites mentioned above has security bits, but for some of them it also has a size chart so you can orde the exact size you need .Thanks again
