Saw Table Rust Removal
Old 06-27-00, 04:22 PM
Guest
Question
I recently bought a 50's-vintage table saw. It's in fine working order, except that the cast-iron table has a fine coating of rust. What would be the best way of removing the rust, without excessively scratching the table surface?
Thanks. rpr3
Old 06-30-00, 08:27 PM
Guest
Thumbs up
I've had pretty good luck using a wall sander and pad with mineral spirits. I rub it down real well and do it as much as is necessary to remove the surface rust.
More than a Carpenter
http://www.carpenter.cjb.net
Old 07-01-00, 09:18 PM
Guest
Post
A Cratex block would work too. You will have some hand rubbing to do, but they are made to remove rust w/o removing any base metal.
