Drill Bits
Drill Bits
How do I sharpen drill bits. I do not have a bench grinder nor do I have the money right now to buy one nor a drill Dr.
Any other methods?
Any other methods?
Most people cannot sharpen a drill by using a grinder. I was a machinist and spent many hours learning how using the proper tools. If you cannot buy a drill doctor, find someone who has one. If you live close to me I will sharpen them for you.
Received 5 Votes
Hello: asennad. Welcome into my Sharpening Shop Forum Topic.
Without a bench grinder or drill bit sharpener, for the time being, select those bits which you will be using for whatever project you have going or intend to use the bits for and have them professionally sharpened.
Sharpening shops should be located nearby. The shops or places to have sharpening done will be listed in the phone book. Also done at some small engine shops and hardware stores.
The costs vary based on the type of bit but non are expensive. Doing it this way for now will get the current project you need the bits for done. Later you can buy a drill bit sharpener.
Sharp Advice.
Web Sites Host, Forums Monitor & Sharpening Forum Moderator.
Accurate Power Equipment Company. Complete Saw and Tool Sharpening Services. TCB4U2B2B Enterprises. Sharp Advice Business Management Services.
Sharp Advice.
Received 5 Votes
Hi: hvac01453
Fully agree. Drill bits are not an easy tool to sharpen correctly. Look easy but not really so. The bit must be sharpened evenly and correctly. If not but it does cut, may be only one side doing more work than the other end or none at all on one side.
Getting the center web even is tricky too. An uneven center web causes the bit to drift off center and or cut off center. Not as noticeable on wood as it is drilling into steel, etc.
Uncorrectly sharpened bits dull faster, heat up quickier, take long to bore the hole and cause users "Grief"...
Grief causes unhappy customers...
Same applies to end mills. One of the most difficult tools to sharpen is an end mill, in my opinion.
However, a good sharpening person can make a huge buck with the right machine and plenty of skill.
Trail & Errors, Practice & Patience creates perfect results.
Reminder: "Work Shop Safety Is No Accident."
Sharpeners Quote:
"I can sharpen almost anything, except a dull mind."...
Sharp Advice.
Sharpeners Quote:
Sharp Advice.
Received 0 Votes
I bought this really great inexpensive devise that sharpens drill bits using a bench grinder. It holds the bit at the proper angle and sharpens it with the curve and everything. There are three angle setting for long lasting, high speed and super sharp. I use the middle setting and it is amazing how sharp they become. It is really easy. I had a bag full of old dull bits and I sharpened every one
Name Of Device
I got one of these drill bit sharpeners at a tag sale last week but there were no instructions with it. It's the type that bolts up to the work bench and you use a bench grinder with it. It's a Craftsman but it looks exactly like a General Hand tools unit.
Does anyone know where I can get a copy of the setup instructions for one of these?
I will probably get a Drill Dr. somewhere down the road but not for some time as almost all my spare money lately is going into building my 31 Model A Tudor.
Thanks in advance.
Pete
Thanks in advance.
Pete
Received 0 Votes
Pete,
Mine never came with instructions, I had to figure it out myself. If you look at it for a bit you can get an idea on how it works. Basically you need to swing it and have the bit just touch the side of the grinder. Then small adjustments on the thumb screw while swinging it side to side. The trick is to count swings or just be sure to do both sides even so the point will be in the middle. Play around, it will make sense.
I just bought a grinder and one of the tool rests has an angled indentation on it that appears to be for drill bits. However I think an 80 grit wheel is too rough for doing drill bits. Or, you can save your dull drill bits, buy a new bit today, and save for a Drill Dr.
I bought one of those plastic things that sharpens bits, chisels (flat blades), scissors, etc, and even carbide tips. It works well but not for drill bits. You can't see the bit when it's sharpening. And it has 2 tabs that follow the flutes, so as the bit goes down into the hole, you never know which side of the bit you are sharpening, resulting in one side being sharp, and the other not. I.e. unevenly sharpened sides.
Plus the motor is really weak. It has a low duty rating.
Does the Drill Dr. have a better motor?
Received 0 Votes
My father was VERY good at sharpening drill bits, using a bench grinder, holding the bit in his hands, with no guides. Where he worked, people preferred his sharpened bits over new ones. In fact, people would buy new sets of bits and bring them to him to sharpen before using them. He sharpened the bits differently depending on what they would be used for. He could put a tip on a bit that would NEVER drift on metal. Good stuff.
I've watched him do it many times. I'd ruin a bit if I tried it like that. Of course, he probably ruined a few as he learned.
Not adding much to the thread, but I just wanted to share that. True craftsmen like my father are a rare breed these days.
Received 0 Votes
Just to add my two cents worth...I love my Drill Dr. for about $100 (actually I got mine as a gift) I always have sharp bits to work with. If you can read these posts, you can easily follow the directions. I use mine a lot and the convenience and safety involved is worth the expense. I probably spent more in any given year replacing bits than the machine cost.
Received 0 Votes
Bit sharpner
Pete,
xxxxxxxx@xxxxxx.xxx
Last edited by DIYaddict; 08-16-07 at 09:18 AM. Reason: Email address removed/This is not allowed and it will protect your email from being filled w/spam
