Which saw blade should I use?
Old 09-06-00, 03:38 PM
Post
I have a table saw and want to build a small cabines. Which saw blade (10") should I use for: 1) 3/4 plywood; 2) counter top (laminate on particle board); 3) laminate?
Thanks.
Old 09-06-00, 07:16 PM
Cool
If it were me, I would use a fine-tooth paneling blade. Good Luck!
Old 09-07-00, 03:30 PM
Post
A fine-tooth paneling blade would work well for the laminate, but perhaps a standard plywood blade would be best for 3/4" plywood. If you're looking for a real smooth cut, you could also use a hollow ground cabinet blade. They tend to be expensive, though. Good Luck!
